Saunier Duval 620 - Wont relight - Novice Needs Help
23 Oct 2005
Hi all
complete novice and boiler virgin here.
I have a Saunier Duval 620d boiler as is always with the first hint of cold weather it has packed in , I now know that this was due to the fuse going on the boilers isolation switch.
I have replaced the fuse and now get a spark but no relight - just to spice things up I have long since lost the instructions and I dont know the relight procedure.
My technique just consists of holding in the only available button !!
Any help/suggestions would be much appreciated or offers of an instruction manual.
Paul
A fuse is a container with a thin wire inside which is designed to melt when the rated current is exceeded by a safety factor of about 1.5.
Why did your fuse fail?
The S-D 620 is a pretty old boiler now and most of them started leaking a long while ago and have already been replaced.
Are you pressing the red or the green button?
Tony
