    Dismiss Notice
saunier duval sd30e
Discussion in 'Plumbing and Central Heating' started by vickie123, 12 Oct 2009.
  1. vickie123
    vickie123
    12 Oct 2009
    3
    Thanks Received:
    Kent
    Country:
    Hi i gave a saunier duval sd30e combi boiler. I bled the radiators yesterday and have got home to a low water pressure light flashing on my boiler and the pressure gauge showing 0- any ideas
  2. Sponsored Links
  3. topping the pressure up with the filling loop. would be a good start.
  4. vickie123
    vickie123
    12 Oct 2009
    3
    Thanks Received:
    Kent
    Country:
    if that means opening the valve with the black handle i have tried that
  5. see if the filling loop that you tried, which will have a braded hose.attached.has a screw driver slot on one of the valves.try turning that.usually though most filling loops have a handle at each end.hence the sugestion of the slotted valve.
  6. kevplumb
    kevplumb
    18 May 2004
    23,712
    Thanks Received:
    925
    depends where i get sent
    Country:
  7. vickie123
    vickie123
    12 Oct 2009
    3
    Thanks Received:
    Kent
    Country:
    thanks, despite being a girl i have got some sense and had figured needed to fiddle with valves however have moved thoses at both ends, independantly and together but to no joy am guessing that maybe there is a reset switch or somthing somewhere????
  8. kevplumb
    kevplumb
    18 May 2004
    23,712
    Thanks Received:
    925
    Country:
    close the valves
    remove silver pipe
    point it into a bucket and tutn on valve
    do you get water out
    being female is not an excuse btw :LOL: ;)
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
