Thanks for the tip but it specifically says 'no use for gaps between floor boards already nailed to joists it will fall out' my floorboards are already nailed to joists!! I assume it's holes and gaps then? Not that there are many or that un-sightly but better filled than not for asthetic and heat loss/draught reasons.
