I would appreciate some help.
The present arrangement I have has zone 1 as our main entry/exit to the house. It is set up as 6 9 B C. 6 for entry route, 9 for double knock, B for being armed in part set B and C for being armed in part set C. The entry time is now set for 20 seconds and the exit time for 10 seconds.
We plan now to use either of 2 doors for entry/exit. The second door is in zone 2.
I have the user guide for the 9800 but!
It does not mention if more than one entry/exit zones can be used. Can I program zone 2 to be an entry/exit zone as well? Using the same parameters I now use in zone 1?
Also in the programming options there is a final exit [5]. When would you use the final exit option? and if applicable can it be used for both the entry/exit doors?
