Hi, I. need help on the above panel which I installed in my house about 15 Years ago. Once when disarmed , the internal sounders went off and error code R2 appeared during a storm. I suspected the antitamper switch behind the 2nd keyboards could have triggered due to a banging front door.. i reset the alarm, but the code did not go away. entered engineer code and removed the main panel cover to access engineering mode. squeezed in the keypad, closed the main panel and keyed in 99. the R2 code still continued and could not exit engineer mode. I disconnected the keypad 2 completely leaving the Keypad 1 connected. (keypad 9825). tried to exit engineer mode, but R2 still shows. The DIP switch on the remaining Keypad is set to 1.
There is now only one keypad connected yet R2 appears on the display and i cannot exit the engineer mode.
Currently have switched off the main powers supply, and disconnected the battery. If necessary, I can reprogram the whole system. but am not sure if R2 will disappear? Apparently the main panel still assumes that Keypad 2 is connected yet its not.
Please advise on what to do.
Will appriciate your help
Vipul
Vipul
