- Joined
- 2 Mar 2020
- Messages
- 84
- Reaction score
- 11
- Country
Hi, I have the above 16 zone panel with two 9930 keypads attached to an SD1 Menvier dialler.
I would like to add another user to the system as per the user manual and find I cannot amend the existing codes apart from the two that I know are in the system. I believe a total of 8 different user codes can be added but I do not know the other 6 that are taken up but not in use.
Following the instructions in the installer manual I have done the following:
1. Entered Engineer Installer Mode.
2. Isolated the mains.
3. Removed the cover.
4. Disconnected the battery. At this point the external sounder starts.
5. Shorted out the NVM and the Kick Start pins.
6. Replaced the battery connections.
7. Removed the shorted pin links.
8. Replaced the cover.
9. Turned on the mains.
The default codes of 1234 are not active, only the existing codes that I know are.
Any help would be appreciated.
Many thanks.
Many thanks.
