I have had trouble for some time in starting the above and it is getting worse until now when I have a no-starter.
I noticed that the glow plug dash indicator sometimes was on and sometimes refused to come on. If the indicator does not light then it is a non-start situation.
I have replaced four glow plugs, I have replaced the temperature sensor, I have changed the glow plug controller (salvage - new £90!). I have swapped around a couple of the relays. I have thoughly cleaned the tdc sensor. Checked all fuses, taken out and cleaned all terminals as far as I can.
Not sure what I can do now, are you able to help. Thanks in anticipation.
