screen cleaner
2 Oct 2016
Essex
Searching on here results in advice re. cleaning the outside of windscreens, but I'm unable to find anything for the inside. Using one of these micropore pads on a stick/handle I've tried plain water, rubbing alcohol or a white vinegar/water mix, but still cannot avoid streaks. Perhaps a mixture of the above would be more successful ?
I've no problem using propriety spray products on the inside of the side windows, but dubious about using them on the 'screen.
Any tips would be appreciated.
I use Mr. Muscle glass cleaner on the inside.....but the screen must be cool. Loads of shop towel to buff and the result is fine.
John :)
Autoglym Fast Glass is fine on the windscreen, it evaporates and leaves no residue. I don't get on with those pads on a plastic stick. I get on better with a couple of normal microfibre cloths.
I like to buy the most expensive branded product i can find, if it's less than a tenner a bottle then
I won't even entertain it. Unfortunately I've ran out so used a dash of fairy liquid instead. Good grief....it worked. (y)
I entirely agree with you from an efficiency standpoint, but my arm/shoulder will no longer tolerate the unnatural angles required & the steeply sloping rear screen of a saloon is impossible for me without the 'stick' (n)
Thank you for your response.
Used that method on windows inside the home, followed by a Karcher window vac. & it works a treat. Unfortunately due to it's physical size the vac. would be totally impractical for 'screens inside a car.
Thank you for your reply.
MIR car polish works well for the inside. A few drops on a cloth, spread, the buff up using maybe a second cloth.
Egg cup full of meths in a couple of litres of water, microfibre cloth dunked in and then well wrung out, clean windows inside then outside, redunking as you go, easy peasy (y)
Thank you for that, think I have some meths. in the shed.
