    Dismiss Notice
Sealant/ glue recommendation?
Discussion in 'General DIY' started by daverave7, 20 Mar 2019.
  1. daverave7
    daverave7
    14 Oct 2012
    40
    Thanks Received:
    Country:
    I'm fixing my daughters hoverboard which needed a new plastic shell. When I came to replacing the shell, there's a few computer boards and speakers fixed to the shell by some kind of resin - perhaps silicone or polymer? I need to carefully remove these and then fix to the new plastic shell. Can someone recommend what type of glue/resin/sealant I should use? Or is anything OK?!!
  2. foxhole
    foxhole
    14 Mar 2006
    15,494
    Thanks Received:
    1,697
    Kent
    Country:
    Hot glue gun may work .
  3. EddieM
    EddieM
    15 Feb 2009
    8,374
    Thanks Received:
    393
    Country:
    You need to identify what type of plastic it is, it may well be ABS.
    • Thanks Thanks x 1
  4. daverave7
    daverave7
    14 Oct 2012
    40
    Thanks Received:
    Country:
    Yes, it's ABS. Just checked the order.
  5. EddieM
    EddieM
    15 Feb 2009
    8,374
    Thanks Received:
    393
    Country:
    Cool, in that case I'd use something like this
    Other, probably more deserving, retailers are available.
  6. Sponsored Links
  7. EddieM
    EddieM
    15 Feb 2009
    8,374
    Thanks Received:
    393
    Country:
    Oh hang on, I've haven't read the thread properly, my bad, yeah hot melt glue probably be fine.
  8. daverave7
    daverave7
    14 Oct 2012
    40
    Thanks Received:
    Country:
    So any cheap (amazon!) hot glue gun?!
  9. EddieM
    EddieM
    15 Feb 2009
    8,374
    Thanks Received:
    393
    Country:
    If you must, yes ;)
  10. cdbe
    cdbe
    22 Nov 2009
    624
    Thanks Received:
    88
    Oldham
    Country:
    My local Poundland was selling hot melt glue guns for.....£2?? Probably best to buy 2 so you can use the second to fix the first when it falls to bits after 5 minutes :LOL:.
  11. foxhole
    foxhole
    14 Mar 2006
    15,494
    Thanks Received:
    1,697
    Kent
    Country:
    The rate the glue melts in a glue gun is usually proportional to the cost .
    You need a lot of patience to use the cheap ones .
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
