Sealey battery charger
20 Dec 2006
Hi everyone.
Just connected my sealey battery charger to my van battery and left to re-charge overnight but the battery is still as flat as a pancake.
It says 20A output on recharge and 80 on boost.
How do I know if the charger is putting out a charging current ?.
The fusible link is intact.
If you connect your battery charger then measure the voltage across the battery it should be somewhere in the region of 13.4v-14v DC.
ok my thoughts
if the battery is completly dead as in nothing works at all maybe theres a fault between battery and the car
the amp gauge on the battery charger will tell you if the battery charging or not
0 reading incomplete circuit between charger and battery
low charge rate the battery is well charged
high charge rate the battery is flat [or nearly or fault on the electrics draining power]
The person asking for help is BigBurn ! ! !
perhaps the copper rod in the fuse holder has melted
:D :rolleyes: :evil: :evil:
But seriously.
If you have a compass, the magnetic type put it under ONE of the leads to the battery ( if the wire can be made to run north south it is better ) and note which the way compass it is pointing. Then turn the charger on. If the needle moves then there is current flowing. Only a very rough test and give no real idea of how much is going into the battery.
Thanks all.
I have suspected the charger is faulty as the amp meter needle stays at zero when turned on.
We used to have a little charger with a needle that jumped up and then slowly returned back down which I think indicated the battery was fully charged.
PS. This one has the correct fusible link fitted.
