sealing a female elbow
14 Jan 2015
Essex
I have a 15mm flexible pipe that I'm wanting to use. I need to install an elbow off of the main feed to connect to the flexible pipe. The flexible pipe has a male end and I am looking to connect the two via an elbow with one female end so the flexible pipe screws straight in. Question is how do i make that water tight?
Thank you
A photo would help to determine what you propose to do,..............oh and a please and thank you doesn't go unnoticed.
sure here is what a female elbow looks like
and here is what a flexible hose looks like.
I want to know how to make the connection water tight please
PTFE tape around the thread or a fibre washer or two inside the female elbow depending on the length of the male thread.
I don't think 45 really meant a picture of the fittings as they are pretty obvious. What you wish to do is a bit unusual though. Usually flexi's would have either a compression or female end on them. It's not really the norm to do a sink connection the way your propose, using a connex female iron with male ended flexi pipes and that may be why 45 is asking for a picture of what you wish to do. Are you sure the flexi pipes aren't compression fittings with the nut and olive missing?
All that being said, fibre washers and/or PTFE tape would be the way to seal male to female as suggested but not the most reliable method for hooking up supply pipes to a sink IMO
They are compression fittings and I could pop a bit of copper pipe in to join the flexi pipe to a normal compression elbow. but that would be a waste as the length needed would be so small. I just figured if i have a male end on the flex and female end on an elbow why not screw the 2 together. I will give PTFE a try.
these are the 2 bits I want to join. the flexi is just a few mm too short to reach which was why i ws going to pop on the elbow.
Many thanks
