I have drilled a 100mm hole through the side of my flat roof for some venting. The hole has breached the felting. What can I use to create a water tight seal between the plastic vent and felt ? I was going to using general purpose silicone but someone mentioned they used it and the bitumen started to seep through the felt???
Also, should I seal the hole first with some flashband ?
