Sealing breached felt
16 Oct 2012
London
I have drilled a 100mm hole through the side of my flat roof for some venting. The hole has breached the felting. What can I use to create a water tight seal between the plastic vent and felt ? I was going to using general purpose silicone but someone mentioned they used it and the bitumen started to seep through the felt???
Also, should I seal the hole first with some flashband ?
Silicone would probably be fine, but Geocell do a kosher roofing sealer - Screwfix 32561. Failing that, and depending on the gaps involved, consider Evercryl (MKM) or Aquapol.
John :)
John :)
Cheers John. Just to confirm, should I use the sealant between the brick and felt or the felt and vent ?
Regards
This stuff remains pretty flexible and does accommodate movement of the felt in the summer months. Apply some in both places you mention to get a good seal.
Just for interest....you say you have drilled a hole in the side of your flat roof.....can you give us a pic, do you think?
John :)
