I need to cut into the plastic risers on an inspection chamber and was wondering if/how to seal the pipes (110mm). I'm doing it for a back drop pipe, and it's only for rainwater. Do I just use sealant around the pipe or is there something better?
It's a round Floplast onePresuming it is square/oblong underground riser you are talking about
I'm assuming you want to connect a back inlet gully or similar that is fed by a downspout into the chamber without digging down to the base.
I don't know if that would contravene any regulations but if not I would think you only need to ensure that it is a rat proof connection. Perhaps something like JB Weld
This is the post that lead me to the back drop. This is domestic. It's rainwater and approx 2.5m in length.To be honest I have only been involved with domestic waste drainage and never industrial which your link refers to. I've never heard of a back drop and personally would have put a rodding eye in the pipe attached to the gully then connected into the base of the chamber rather than break into the riser. But I can see what you want to achieve the way you envisage doing it. If the new drain is just for surface water and not far from the chamber then there probably no real need for rodding access.
