    Dismiss Notice
Sealing shower
Discussion in 'Plumbing and Central Heating' started by jrussuk, 16 Sep 2019.
  1. jrussuk
    jrussuk
    30 Jun 2007
    91
    Thanks Received:
    Kent
    Country:
    Hi
    I need some advice on re applying sealant in my shower. We have had some movement and a gap in the corner of the shower has appeared (I've attached a picture) The gap is over 7mm.
    How would be the best way of re sealing this? I was going to use CT1 sealer. piccy.jpg
  2. Sponsored Links
  3. Gorners
    Gorners
    6 Dec 2015
    167
    Thanks Received:
    5
    Country:
    Wow. ‘Some movement’ looks to be putting it lightly. Hard to say 100% from the photo but is the thick white bead to the left of the gap a thick bead of silicone already? If so that gap looks to be well over 7mm - far too big to properly seal with one full bead of silicone.
    Ideally you’d remove that and put a thicker bead across the entire gap but as I’ve already said that’s almost certainly too big. You can try filling the remaining gap with more silicone (CT1 fine as you’ve mentioned) but I’d be amazed if that didn’t crack again soon after.
    You could be looking at a retile here I’m afraid. Is this a new house? Wouldn’t expect that much movement on a settled property.
  4. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,941
    Thanks Received:
    1,982
    Hertfordshire
    Country:
    Looks like you are moving postcodes.
    Andy
    • Like Like x 2
  5. Madrab
    Madrab
    4 Oct 2012
    8,036
    Thanks Received:
    2,274
    East Renfrewshire
    Country:
    Looks like it's been a large grout line that has gone. I'd probably look to re-grout and then re-seal but if it moves again then it'll go again.
    I'd be more concerned about what else has moved at the tray level if that's what the wall looks like.
  6. jrussuk
    jrussuk
    30 Jun 2007
    91
    Thanks Received:
    Kent
    Country:
    No its an old 1910 property. Had a structural surveyor look at it and he blamed it on last years hot summer. At the tray level it looks all good and sealed. The photo is taken a lot further up the wall where its at its worst. Do I "backfill"the gap with anything before resealing?
  7. dilalio
    dilalio
    20 Mar 2009
    7,774
    Thanks Received:
    1,249
    Potters Bar
    Country:
  8. Sponsored Links
  9. jrussuk
    jrussuk
    30 Jun 2007
    91
    Thanks Received:
    Kent
    Country:
    Could i fit that vertical?
  10. dilalio
    dilalio
    20 Mar 2009
    7,774
    Thanks Received:
    1,249
    Potters Bar
    Country:
    I linked to it on the basis you would be! :)
    I don't think you need to worry about a guarantee on it ;)
    It would look better than a massive silicone bead and likely more waterproof and giving.
  11. jrussuk
    jrussuk
    30 Jun 2007
    91
    Thanks Received:
    Kent
    Country:
    nice one
  12. Madrab
    Madrab
    4 Oct 2012
    8,036
    Thanks Received:
    2,274
    East Renfrewshire
    Country:
    Not sure but you may find it difficult to get it to be absolutely waterproof against all that mosaic.
    Normally I wouldn't disagree with the lads on here but I have to be honest, I don't like them, long term they're not very good on anything apart from a totally smooth surface in my experience.
    I'm actually going to a shower on Thursday that had them fitted a couple of years ago, the shower tray has since moved slightly, cracked the grout and seal at the tray edges and as it has all been hidden behind the seal for a quite a while, the water has leaked through the wall and wrecked the whole bottom edge of the plasterboard on 3 sides. So it's bottom row of tiles out, tray out, rebuild the plasterboard, tank and then refit everything.
    I'm not suggesting that will happen here, but the wall has already moved and rather than covering it, I'd want to fix it.
  13. dilalio
    dilalio
    20 Mar 2009
    7,774
    Thanks Received:
    1,249
    Potters Bar
    Country:
    I agree with you @Madrab. My suggestion was aimed at the OP as a diyer and for a short term fix.
    Unfortunately, the only true remedy would be a retile, or if it was a landlord/tenant issue, I'd overclad the lot in aqua boards.
    However, a bath/shower seal (such as the one I linked to) may suffice in the vertical, if no more movement occurs, and I would be sealing it in place with silicone as an adhesive.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
