I've got into bother replacing a broken lamp with PIR.
I have 1 cable with 4 wires (red, blue, yellow and earth) feeding the primary lamp with PIR. Within the lamp there is a 3 place terminal block to connect these wires to. From the terminal block there is a brown and blue to the PIR switch. From the PIR switch there is a red to the bulb holder. From the bulb holder there is a blue back to the terminal block, connecting to the blue going into the PIR switch.
Connecting the cable to the terminal block (live, earth.common) leaving the yellow unconnected makes the primary lamp work. I cannot work out how to connect the yellow to get the secondary lamp to work using the PIR. If I connect the yellow to the blue from the bulb holder both lamps are dim.
Help!
Help!
