That's how the lamp connects to the supply. Indeed, there are only two types of lamp that do not require connections, induction lamps and some types of cold cathode lamp.
That's not what I, or I suspect 99.99999999999999999% of people mean when they use the word "connections".
So in your strange dictionary, what does "connections" mean for something other than a luminaire, for example an air conditioning unit or a radon fan? It can't be where a lamp base makes contact, so what is it?
Please remove the lamp from your batten holder, stick your finger up the lamp hole and ask someone to switch on. Please.
Tw@.
Anyway, the point is moot. The issue is whether cabling along an outside wall to a light fitting is notifiable or not. BAS has made his point that neither joint boxes nor lighting fittings have exposed connections, therefore they do not fall foul of Additional Note (i).
No, but they fall foul of the actual words in the actual law.
It's clear from considering Additional Notes (g), (i) and (j) that the criterium is whether the cable crosses the garden or not. If it does, it's notifiable; if it does not (subject to other circumstances) it's not notifiable.
How can that possibly be clear when (j) isn't talking about cables which come within the scope of Part P in the first place?
According to your definitions, installing A is non-notifiable but installing B is notifiable.
Please explain the the logic behind this, and why it has a consistent and safety-related basis which it's reasonable to believe that the people writing the AD felt necessary to clarify because of the significant differences between the skills needed, or the risks involved, in installing A vs B.
Neither the law nor regulations can possibly be logical or show significant differences when they seek to draw a line between almost similar shades of grey.
If you've got two possible alternative interpretations of something, one introduces illogicalities and inconsistencies, and you can't think of a reasonable way to explain why it should be that way, and the other one does not have any of those problems then the first one must be wrong.
Going back to your notion that "connections" means the lamp base terminals, and your definition of "exposed", then according to you a luminaire which doesn't require a tool to change the lamp is notifiable, but one where a tool is required is not. Even if every single other aspect of the items is identical.
Since changing the lamp can have no possible bearing on the difficulty or the safety issues of installing the item, why do you think it makes a difference to whether it is notifiable?
Surely your definition doesn't introduce an illogicality or inconsistency, does it?
And we can also, quite easily, imagine a luminaire where a strong man could change the lamp without needing a tool but an old woman with arthritis in her hands could not.
So according to you the notifiable/not-notifiable choice now hinges on the results of a strength test carried out by the person(s) who will be changing the lamps.
Hmmmmmmmm.......
For example, we all, I think, accept that the inside of an attached garage is not outdoor. Even if the garage door is open.
Neither is a detached garage.
But what if one wall is left out? Not much more than an open door eh?
But crucially it is permanently open, so there is a significant difference.
Now if two walls are missing? Three? It's now a car port, but is it outside? Are you going to define a building with only one wall and a roof as outside?
Yes.
