hi have this valve on gas central heating and it is only working on the hot water. i have manually put the lever in the middle which has got the rads working care of this forum (thanks a million). I think that the top slides off it, is it an easy job to swop over, or should i get a heating engineer out, and is the temp fix ok to after the weekend. as you may be able to tell from the above questions i have very little experience of heating systems. all help would be welcome cheers dim
