Self Levelling ...Err No!
21 Jan 2013
Cleveland
I tried some of the screwfix self levelling compound in my 2m x 2m toilet, which had a concrete floor, I needed to raise the level and also level any deviation on it..
Problem being when I put a straight edge on it now, its not level and the side are a fair bit out pushing 8mm...
I'm not keen on self levelling compound any more its more hassle than its worth, but I thought I'd give it another go, and the results as mentioned were poor..
My question being, how can I rectify this, someone suggested placing sand down to level like silica sand as I'm only putting laminate down in the room..
Any suggestions... alternative ideas, patch it up or rip up?? :(
use the green felt type sheets as underlay as they will take out the amount of discrepency of 8mm which you have.
The compound does'nt 'self level' on it's own, it takes some skill when it's spread on by the person laying it, to build the low areas up and keep the high areas at a minimum coverage. You should use a straight edge whilst you are laying it to ensure that the level is going down evenly. Once the level is achieved, as the compound dries, it will dry uniformally. Once the floor is dry you can use a rubbing block to even out any trowel marks etc (not 8mm of difference though).
There is definately a 'knack' to getting it right, and there are some products that are easier to use than others. F-Ball and Ardex seem to be the choice of many pro's, I know my fitters would'nt touch any of the DIY 'sheds' products through past experiences.
