Self-sealing screws and washers
30 Dec 2008
Cumbria
Bit of an odd one, this! I'm trying to roof a garden shed with recycled plastic sheeting. It appears to be an ideal material in many respects, but suffers from enormous expansion and contraction with temperature. The easiest way to get round this would be simply to drill greatly oversized holes and use some sort of flange-headed screw, not done up too tightly, so that the sheet can move under them. I'm looking for something a bit like a Tek screw, that comes with a washer with a bit of a sealing pad on the underside - but bigger. Ideally something with a head about 3/4" across, maybe even a bit bigger. Do such things exist? I can't think what to search for.
Brilliant! Thanks! I don't suppose you know what diameter the clear plastic ones are? (First Screwfix item number you posted). I like the idea of the little snap cap over the top.
