Not necessarily - they mention metal as a (fairly obvious) example of an acceptable 'non-combustible' material.The regs imply metal is the way to go though...
Kind Regards, John
I thought work in a kitchen was notifyable regardless of what took place?
Not any more.
Fair enough, but when was this "was" you had in mind? Given ...I've highlighted the key words to make it clearer.Not any more.I thought work in a kitchen was notifyable regardless of what took place?
.... there seems to be pretty good chance that the work in question took place after 1st April 2013, hence after a time when you "was" would have been correct.... A couple of years ago I had an electrician (properly registered) come to...
If the mains cut out is replaced then an RCD and proper earth would be fitted at the same time which would bring everything up to today's standard and then he would sign it all off as meeting today's requirements).
I have known DNO's take responsibility for isolation switches after the meter but for clarification, westie is the best person to ask.
I would say that was probably not notifiable work. Although additions/modification to circuits in a kitchen was notifiable in 2006, the rules then if force said that:I had the kitchen lights swapped from strip lighting to recessed ceiling lights (240V but with LED bulbs, no change to circuit) in 2006.
... was not notifiable.1. Work consisting of -
(a) replacing any fixed electrical equipment which does not include the provision of— (i) any new fixed cabling; or(ii) a consumer unit;
Provided it was an existing circuit, that would definitely not have been notifiable work in late 2013.... I had the old cable running along the garden fence replaced by a new and more outdoor-proof cable at the end of 2013.
Even though it's probable that none of the work was notifiable, he should have issued certificates for both those jobs, even if only Minor Works Certificates.Both were done by the same, fully registered, qualified etc etc electrician, but because he didn't issue me with a certificate at the time as he thought the work was pretty minor so didn't need certifying ...
There is no requirement to bring everything up to today's standard, but, as above, he should have issued certificates for the work that he did do.(his argument is that there wasn't an RCD in the consumer unit for the kitchen, though there is one to the shed. If the mains cut out is replaced then an RCD and proper earth would be fitted at the same time which would bring everything up to today's standard and then he would sign it all off as meeting today's requirements).
As I implied before, if I were you I would be asking my solicitor to tell the buyer's solicitor that if they don't desist from all this silly fuss that you will withdraw from the sale!Frankly given how persistent our buyer's solicitors have been, I expect they will be asking me for proof that I got the building regs people out to inspect the Hoover the last time I had to replace its fuse, or to inspect the living room lights to check I'd replaced the bulbs correctly.
Tell your buyers that they either buy the house as it is, i.e. as it was when they viewed it, for the price they offered, or they can FOAD.Frankly given how persistent our buyer's solicitors have been, I expect they will be asking me for proof that I got the building regs people out to inspect the Hoover the last time I had to replace its fuse, or to inspect the living room lights to check I'd replaced the bulbs correctly.
