Semi detached Party walls
10 Apr 2021
Does anyone know about the building standards with regards to semi detached party walls ? Were all properties designed to have cavity walls ? I have a 1950s no fines property so I am guessing the party wall is of a similar make up, but I'm not sure whether cavities were ever installed in no-fines party walls, or whether that was even possible.
Probably solid, one brick thick (215mm) walls, of that period.
[Wimpey] no-fines was a system were all the wall panels were of solid concrete, the party wall typically 250mm.
Just drilled into it, its not a no-fines. Drilled material is light grey so looks like a standard block thankfully. Weirdly enough, I have gone in about 2.5 inches and can feel a cold breeze?? This is ground floor of a 2 storey building.
Any complaint, from next door, about a new hole in their wall ;)
Could be hollow clinker blocks.
If this is an ex- council house, get in touch with the council's housing department and they will tell you what system it is and the construction.
I was once chasing a wall in an ex council flat ,20mm max when I saw the back of tiles in next doors flat .
