What is the preferred method to connect two separate appliances into a single cooker outlet?
I don't have the specs to hand but iirc both the oven and hob (electric) said they should be wired on a minimum of 2.5mm.
The circuit is fed from a 30A rewireable fuse, via 6mm T&E, via a 45A cooker switch (no socket outlet) to the cooker outlet.
The oven is sited in front of the cooker outlet with the hob directly above.
Would it be acceptable to use 4mm for each both from the one outlet, assuming I can get a pair of 4mm's into the terminals?
