Service Fuse Size.
13 Dec 2006
Tyne and Wear
I've moved to a 1930's house which has been rewired but i'm having an electric oven, hob and shower installed.
I'm told the house is likely to have a 60A service fuse and i'm concerned the extra load may cause problems.
Will this need upgraded to 80/100A ? and can an electrician do this or do I need to contact the electric company ?
Hi Diesel,
Your DNO, (local elec supplier) will upgrade your main fuse from a 60 to a 100a, always free of charge around here. Do you know what type of system you have TT TNCS etc ?? If you are on a TT (overhead) type supply, they may be able to convert it to a PME set-up, also at no extra charge !!!
Hope that this is of some help.
on a side note electric hobs are pants, they cost more to run and dont work as well.
showers are 50/50 pros and cons (main pro is it works when the boiler is broken, main con is they dont have a good output). electric fan ovens are fine.
Not so. MEB charge £99 for this service. Not sure of others.
No charge in my area, sorry, I should have stated that regional costs may vary. :oops:
Not strictly true. Sealed plate hobs are as you say pants, but decent ceramic, and especially induction hobs are moer efficient than gas.
