- Joined
- 24 Aug 2009
- Messages
- 2,664
- Reaction score
- 281
- Country
Hi
I need to build an external staircase ( domestic use) using pressed steel-steps.
The side-pieces are 50 mm x 250 mm x 6m long and the steps will be 800 mm wide.
I've never built anything like this before so, going by logic that the loading is not going to be enormous, envisage one pair of intermediate vertical supports ( probably wood ).
Would you agree ? Will probably use 120 mm dia posts because I have some on hand.
When the steps reach ground-level I thought it would be a good idea to keep the wood off the ground and will build a couple of small "pillars " the height of the first riser to achieve this.
Please let me know if you think there is anythin missing.
By the way, I live in France so , depending how you see it, I either don't have to worry about a BCO or there is no BCO to get advice from.
