I've just had a whole new boiler system and controls fitted, consisting of the following:
Vokera Compact 29A combi condensing boiler
Honeywell CM927 room stat.
TRVs on most rads
The boiler has the normal flow temperature controls on the front for setting the main boiler running temperature and hot water temperature.
Is there an optimum setting for the flow temperature to ensure the boiler is running in condensing mode as much as possible? I initially thought that running the boiler temperature high and letting the TRVs and room stat do the work was the correct was to do it, but I hear that doing this would result in the boiler not being able to condense properly.
The boiler doesn't acutally give a readout for the flow and return temps, but I'm able to measure it myself at the pipes.
Any advice?
TRVs on most rads
Any advice?
