Hi all
I recently removed a structural wall in a Victorian terrace to create an open plan living area. The wall separated the front and rear rooms at ground floor. I had a structural engineer calculate the beam size and padstones I required. The required padstones were 440x215x140. And they sat parallel underneath the beam and on top of a pier wall.
I am renovating a new property and want to do the same thing but this time sit one end of the steel on the external wall, not on a pier wall. As the exterior wall is a 9 inch I can take the inner sleeve of brick out to create a whole in which I can sit a padstone of size 440x215x100 in and it will fit fine.
When steels are sat on a 9inch exterior wall is it usual to use a thinner padstone like this?
Hope that makes sense?
