Hi All..
Hoping for a bit of assistance with setting up a TRV.
Living room has 2 rads (which have recently been removed, flushed and refitted). One Rad gets warm pretty quickly but the other struggles. Both outlet valves (Lock vlaves??) are open and working ok.
I've taken the thermostat part off the TRV so I can see the pin and have tested the working of it by manually pushing it down to check for sticking (all tests OK).
My question is, what do all the little numbers mean that surround the plastic casing where the brass pin travels up and down? The numbers are from 1 - 6 and I have turned this part with some pliers which causes the actual sound of the water flowing into the rad to change (but just because the sound turns to a 'whooshing' noise I'm guessing this doesn't mean that the water is flowing in more freely!). Not sure what setting to have here so have just returned the valve back to its original setting. This valve also has an outer sleeve nut type thing.
TRV's are made by 'Lifestyle' and were fitted before I moved itno the property. Have also scoured the net to see if I can find a PDF or installation manual for them.........to no avail.
Can anybody advise or help?
Many thanks in advance.
Marco
Marco
