Hi all
I have a bad blockage on the sink waste. Tried wire rodding etc to no avail. Think the problem is the waste disposal unit.The run is very long and goes into a sealed stack pipe in a block of flats.In total probably 7mtrs in length and NO access as it is glued joints on 50mm pipework reduced to 32mm for waste fittings.Also has 5 ,yes I said 5, bends @ 90 degrees two of which are joined to go right and left immediately ! When I ran the wire through it will only go so far because of all the bends. So question is ,what to do before calling Dyno or someone in. Any input gratefully recieved thank you
