Severe waste blockage
12 Mar 2009
Hi all
I have a bad blockage on the sink waste. Tried wire rodding etc to no avail. Think the problem is the waste disposal unit.The run is very long and goes into a sealed stack pipe in a block of flats.In total probably 7mtrs in length and NO access as it is glued joints on 50mm pipework reduced to 32mm for waste fittings.Also has 5 ,yes I said 5, bends @ 90 degrees two of which are joined to go right and left immediately ! When I ran the wire through it will only go so far because of all the bends. So question is ,what to do before calling Dyno or someone in. Any input gratefully recieved thank you
Hmmm, sounds like Mr DIY has been at it again, the 2 90's shouldn't be there and I guess the fall over 7m is incorrect also :roll: I would suggest you get a good local plumber who would redo the complete waste pipe fella... If no waste or water is getting away, the lovely growth of all the nasty germs will grow quite quickly. Hope you used gloves when you looked at the pipe :wink:
I would take off the lot and renew with pushfit. Cost you less than £10 and be cheaper than a call out. :D
Or why not put a big bucket under the pipe at a suitable point; put your rubber gloves on; cut the pipe and fit a tee with an access plug.
Before fitting the plug see what you can shift with your wire thing...
Just what I thought. Cut it out and start again-properly!
Access plug is very good possibility as its gonna happen again due to the waste disposal unit
Thanks for the replies. I'll have one more go first though, hate to give up
