Sewage smell from Washing machine trap?
9 Oct 2007
For last couple of months, sometimes when our washing machine does its first rinse/empty, there is a very noticeable sewage smell from the outlet. We have an open upright stand-pipe type, with a u-bend trap at the bottom, like this:
http://www.screwfix.com/prods/18640/Plumbing/Wastes-and-Traps/Washing-Machine-Trap-40mm
Our drainage goes to septic tank, which we had emptied 3 months ago, and the guy rodded the drains at the same time to ensure no solids trapped in the pipes. Our utility where the w/m is located is next to our bathroom, both on the ground floor. Toilet is "downstream" of the w/m outlet plumbing. I took the w/m "stand-pipe to pieces, and the u-bend is clean, no sign of any blockage or debris and contained water, so how is this smell getting through? It is possible that the u-bend is syphoning out and therefore running dry? If this was the case, I guess there would be a smell all the time, but its only evident when the w/m drops its first lot of water and subsequent rinses seem to "flush" the smell away.
Any suggestions appreciated.
Thanks :wink:
sounds like u lossing trap seal fit hepworth stright trap to it and this should solve the problem
You mentioned the possibility of the u-bend syphoning out and running dry, which could allow sewer gases to escape into your utility room. This is indeed a possibility, especially if the stand-pipe is not installed correctly or if there's insufficient air gap between the stand-pipe and the washing machine outlet hose. Installing a proper air gap or anti-siphon device may help prevent this issue.
A photograph of your own entire waste and drain, including the route of the hose from the appliance, would be useful
