    Dismiss Notice
sewer gas smell - downstairs wc
Discussion in 'Plumbing and Central Heating' started by sandyman44, 20 Apr 2016.
  1. sandyman44
    sandyman44
    13 Apr 2016
    58
    Thanks Received:
    Country:
    hi
    I have a back to wall pan in a downstairs cloak room, soil pipe comes out horizontally into a flexible connector that goes down into floor behind the pan underneath the concealed cistern. This particular pan has been installed for about 10 years, on and off have noticed smells, but its getting more often so motivated to do something about it. Prior to that (previous owners, since house was built) it was a close-coupled.
    Its a sulphurous smell, it happens mostly but not exclusively when we flush, however I am pretty sure the U bend is not being siphoned , the water level in the bottom does not drop, no gurgling etc. This wc is at the front of the house, about 5 yards from the manhole. There is no venting on this leg. Another sewer line runs from that manhole under the house to the back, where there is a internal soil stack that vents through the roof. There are two upstairs bathrooms on this stack and there are no issues with anything in those bathrooms. All water using points in the house drain nicely so we are not blocked - its just the bad gas smell thats the issue.
    I've tried to get a better seal with silicone between the flexi-connector and the floor entry, on the guess that it was foul air coming back up through tiny gaps, but that made no difference. The flexi-connector is pretty tight on the back of the pan as well. Is trying to get a really good seal the way to go or something else to try?
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    60,516
    Thanks Received:
    3,171
    Dunfermline
    Country:
    Cook Islands
    Have you got a Durgo?
  4. sandyman44
    sandyman44
    13 Apr 2016
    58
    Thanks Received:
    Country:
    spent a few hours reading about those before I posted. pretty sure the answer is a no.
    The stack at the back of the house is vented through the roof (its a 1970's house), this serves the two upstairs bathrooms. No smell issues there at all.
    The downstairs WC, the soil outlet is on a flexi connector, into a hole in the floor, which by process of it-cant-go-anywhere else, must join a sewer line going out of the house towards the manhole which is only a few yards away. I have some of the original plans as well which appear to confirm this route. The WC is adjacent to the wall so the length of this sewer line thats inside the house is pretty short. On this (short) leg of sewer line, there is no ventilation.
  5. Jackrae
    Jackrae
    20 Nov 2012
    2,003
    Thanks Received:
    324
    Dumfriesshire
    Country:
    Wooden floor or solid floor.
    If wooden floor there's a chance your outlet has become disconnected or the sewer line has fractured.
  6. HERTS P&D
    HERTS P&D
    9 Apr 2010
    8,721
    Thanks Received:
    1,236
    Hertfordshire
    Country:
    Blocked manhole? Lift up any manhole covers and check that they are clear.
    Andy
  7. sandyman44
    sandyman44
    13 Apr 2016
    58
    Thanks Received:
    Country:
    solid concrete floors.
  8. sandyman44
    sandyman44
    13 Apr 2016
    58
    Thanks Received:
    Country:
    yes I can, (If I can find a lifter) but nothing leaking anywhere, no drainage problems, and the upstairs bathrooms drain into the same manhole and there is no smell from those.
    to me it feels like the positive pressure from the flush is pushing the foul air to find a way out to atmosphere, which is why I was thinking it might be trying to get out of small gap in the flexi pipes seal into the floor.
  9. TCCHeating
    TCCHeating
    4 Mar 2013
    2,883
    Thanks Received:
    709
    Country:
    Is there a wash basin in the cloakroom?
    If there is are you sure the smell is not coming from this? Possibly due to siphoning of trap
    • Like Like x 2
  10. Sponsored Links
  11. mfarrow
    mfarrow
    2 Nov 2009
    2,120
    Thanks Received:
    242
    Warwickshire
    Country:
    Can you photograph the pan connections into the sewer?
  12. dilalio
    dilalio
    20 Mar 2009
    6,249
    Thanks Received:
    860
    Potters Bar
    Country:
    Beat me to it @TCCHeating (y)
    OP: fit an antisyphon trap to whb if there's one in the room.
    Other things to consider are...
    Damp in walls or floor from source other than waste.
    Does cistern have traditional overflow pipe to outside, through which, odours could be entering cistern and boxing.
    Does the room have an extractor? Could one be fitted?
    Some 'cloakrooms' are just not good for airflow, are always sealed off from rest of house and eventually pong a bit!
    My downstairs shower room with wc and whb is in the middle of the house with no external walls or window... I put a powerful extractor in there and the only time it has a bit of odour seems to be in the midst of very damp weather, when the water table is high and the ground sodden- even then it's a damp smell and not a sewer smell!
  13. hazetimesfive
    hazetimesfive
    1 Dec 2011
    2,986
    Thanks Received:
    325
    Surrey
    Country:
    does the toilet have an internal overflow or external?
  14. dilalio
    dilalio
    20 Mar 2009
    6,249
    Thanks Received:
    860
    Potters Bar
    Country:
    I asked that! :sneaky:
    • Like Like x 1
  15. TCCHeating
    TCCHeating
    4 Mar 2013
    2,883
    Thanks Received:
    709
    Country:
    Ah. But you've never been to one of my curry nights mate;)
    You'd need a merlin engine powered extractor fan to cope with a dump the morning after. Trust me:mrgreen:
    • Like Like x 1
  16. dilalio
    dilalio
    20 Mar 2009
    6,249
    Thanks Received:
    860
    Potters Bar
    Country:
    Or a 'Windy Walla' o_O
  17. sandyman44
    sandyman44
    13 Apr 2016
    58
    Thanks Received:
    Country:
    yes there is , and I'm not 100% sure its not. however the feeling is that the smell appears as soon as you've flushed, not after the hand wash, but could be wrong.
    not getting the smell at the mo so can't check.
Loading...
Share This Page
