- Joined
- 29 Oct 2009
- Messages
- 426
- Reaction score
- 31
- Country
Hello all, I have had a look at some previous posts relating to my question. But they all seem slightly different circumstances to myself. Hopefully someone could assist me with a few questions to help m e on my way to DIYing.
Symptom
The neighbour from about 5 doors away appeared to inform me the drains were blocked "again" which was news to me as I have only lived here since christmas. Upon looking in manhole marked 1 it was full of waste and manhole 2 was empty. I rodded out all the pipe between the manhole and It all gushed out an through the system. The rate of fall is very shallow through my property and the waste seemd to move away slowly.
I put the plunger attachment on the rods once it was clear in the pipe to ream out all the nasties and fat etc. but it got stuck about a metre into manhole 2 towards manhole 1. It was suggested to me that the pipe may be jointed there and could of dropped or me damaged there.
Work carried out so far
So far I have cleared the earth from manhole 1 to 2 and the pipe appears to be a salt glaze 4 inch pipe with concrete on the top of it.
I intend bung the manhole 1 and then cut out the pipe between 1 and 2 and lay a six meter length of plastic pipe on shingle etc etc....
Questions I have
1. Once the pipe is removed and the new length fitted in place at the manhole. What would be the best way of fixing it to the manhole and sealing it. As I will need to unbung the manhole asafp after the job as there will be about 25 houses worth of poo and bathwater backing up. The pits are concrete in the bottom where the pipes connect and red brick construction up to the manhole.
2. Could this of been an insurance job. Although the donkey work is all but done now. And am I really responsible for the upkeep of this pipe as all my streets waste uses it.
Thanks in advance for the afvice.
I already got a quote from a local bloke to sort it for £375+VAT. Which I thought was a bit steep as I done all the donkey work already....
Regards,
Rob[/b]
Symptom
Questions I have
Regards,
Rob[/b]
