For a large and in some places double storey raised decking structure I am building I am wanting good founds for concrete support pillars.
To avoid having to reroute various pipes and services the most sensible approach is to do 3 strips of shallow founds which the support pillars will be set into (effectively like 3 sets of floating founds).
So I’m thinking to do shallow trenches approx 600mm wide and fill with about 50mm concrete, put a 50mm approx. steel reinforcement ‘lattice’ on top and concrete on top of that.
I will get structural engineer calcs etc, but before I do was after some practical advice on how to construct this kind of shallow steel reinforced found,; for example I’m thinking a 50mm ‘mattress’ of steel mesh but how would I build that - can you buy prefab sections? Also if there is any common ways of creating a shallow steel reinforced found, what might be common overall depth of such a found, and any idea how strong it could be..
Thanks in advance for help
