Shaving/Trimming off side of Oak Veneer Door
NHW
21 Jun 2013
The current door that I have is an LPD Carini 762mm x 2040mm
My existing doorframe is 762mm at the top and 755mm at the bottom so its about 7mm out. I also need to leave a 2-3mm gap inbetween which means I will have to roughly shave off about 10mm total.
I was thinking that the best way to do this would be to shave 5mm off each side to give me the right size. I spoke to LPD and even though they 'recommend 3mm' They said that you can go upto 5mm each side.
What is the best way to DIY this? would it be to use an electric planer?
I trimmed mine down using a track saw, barely needed a sand afterwards.
Ah thanks I don't have a track saw but I think I'm taking it to a timber merchant who said they can cut it for me. Do you mind if I asked what did you do once cut? Did you varnish/oil the newly cut sides for protection?
By coincidence I think I have the same doors (7 panel?). Mine were the unfinished versions so I just gave the whole lot 3 coats of varnish (I think it's a water based version from Screwfix).
Haha yes its the 7 panel one. I got the pre-finished so it was abit annoying to have to cut but i took it to my local timer merchant and they charged £12 to do the side cuts and to cut the bottom. Saved me alot of effort to be honest. just varnishing the sides now and then hopefully after 2 more coats they will be ready to hang. Thanks for the advice btw
Wow, that is a really good price.
