- Joined
- 1 Aug 2013
- Messages
- 4
- Reaction score
- 0
- Country
Hi great site..Hope you can give me a few pointers regarding putting down a base for a shed.
I am thinking of getting a 12x12 ft wooden shed .I was thinking of removing some of the grass in a 12x12 ft area where the shed would go and lay down some flag stones with sand and cement mix underneath the slabs .once done i intend to lay the shed onto 5 12ft treated skids ..
will this work ? or could i just tamper down the area once grass removed and add some plastic sheets to stop the weeds coming through and then fill the area with those stones you can get from a builders yard .
Once a level surface is done i would lay the skids on top of the stones for shed to go on,only trouble here is would the weight of the shed sink into the ground.Any ideas welcomed that would be cheaper than a concrete base for a novice to go at.
Would the slab idea be better ? Thanks
