I looking to to make an 8x6 timber shed base. the idea is that it will sit on the ground and I will use stakes to hold it in place. The question i have is what kind of wood should I use. I have decided on 3x2 but am unsure if just getting pressure treated 3x2 will be ok for it to sit directly on the ground. The 2 links below, one to wickes which says it cannot be in direct contact to the ground and one to B&q which says ok for all outdoor projects. Which one should I be going for? I dont want it rotting away after a couple of years? Many Thanks
http://www.diy.com/departments/timber-sawn-treated-t47mm-w75mm-l2400mm-pack-of-6/570349_BQ.prd
http://www.wickes.co.uk/Wickes-Treated-Kiln-Dried-C16-Regularised-45x70x2400mm-Single/p/166401
