you always need a stop off some sort otherwise the door and or gate will act as a leaver and try and pull the hinge off
it also helps to line the door up and in case off a curve developing gives you something to push against to hold the curve in check
aaannnddd it removes the gap to look through or for draughts and rain to get driven through
OK thank you both, so my question is, with a stop added, what happens about the surface mounted rimlock and keep? Is it just a case of cutting away some of the door stop for the keep to be put into position? So this is for a door that opens outward with a rimlock with a latch that reverses.
easier to knock in a wooden block about 4ft up then fix lock ---lock door then fix the stop
remember your likely to have cladding and frame all around the door opening
also your lock will be on the back face off the door on the frame or a rail so the bolt off the lock may line up with the back face or need a keep in the frame
