I have an old shed in the garden which was there when property purchased and has electrics for 2 double 13A sockets and a strip light - also in place when bought - long time ago now.
The shed is basicaly falling apart and I want to replace it. Thats the easy bit - its the electrics giving me some concern. The 2.5mm TC&E supply cable goes out through the wall in the kitchen behind one of the units and is impossible to get at to discover its route without demolishing the drawer pack unit. I cannot trace it back to the Consumer Unit as a result and there is no dedicated MCB on the CU (or marked as such) for it. I cannot therefore tell if it spurred off downstairs/kitchen ring but that is what I suspect. The cable must go under the sidepath and come up into the shed through the concrete base. Its impossible to know whether the cable is in conduit (or whatever) without digging up the path although that might come perhaps clearer when the shed is demolished.
The distance from kitchen wall to shed is approx 4 feet.
Inside the shed is a small fuseboard but it has no RCD.
So my question is this. As I have no intention of providing either aditional sockets or lighting will it be OK to remove the shed around the electrics (ensuring its dead first of course) and erect a new shed around the electrics. I would want to put a small modern CU with RCD in place of the fuseboard.
I know that external electrics are Part P but as I'm not actually changing anything (yes I know the present cable isn't armoured) would this count under the like for like replacement category or do you think I need a PArt P Sparks? I'm doing this on rather a small budget and am worried that I might have to shell out a small fortune if its necessary to bring the whole lot up to Edn 17 spec by a Part P sparks.
Yes I know full you don't compromise safety for the purpose of saving a few bob but I'd be grateful for a steer or two from you learned guys.
TIA
TIA
