Hi all,
Really not sure which forum to put this under, so appologies if its better suited elsewhere (I did a search on shed first, and most seemed to be in here).
I would like to re-enforce/improve the floor of my pre-built shed (which is T&G), and a neighbour who did the same suggested 18mm ply as that is what he used. I have a smaller shed which came with an OSB floor, which appears to be doing fine, and I was wondering which would be a better idea, the ply or OSB ? Neither are taking any weight per se, as that will be on the existing base, this is just to firm it up and hold it all together a little more.
Ultimately I may skin the inside as well, any suggestions on what is best ? I assume ply as its more expensive, but given how things are at the moment, I wondered about OSB
Thanks in advance,
Best Regards,
Dave
Thanks in advance,
Best Regards,
Dave
