Shiplap Fence onto block wall
7 Jan 2016
Ireland
Hi, looking for some help with a fence im putting up against a block wall
Its 2.4m long x 2.1m high. Iv ordered 4.8m shiplap as there in 2 walls to be done and 50x35mm for frame.
Im guessing i make the frame 2.4x2.1m with 600mm centers and screw that to wall the screw the shiplap planks to the frame. Is that it or am i missing anything?
What size screws do i usefor frame and boards and wall screws?
thanks
How high is wall? I could see the thin frame snapping under strong winds .
Might be better with just vertical battens on the wall so air and water can pass through/round it.
The wall is 1750mm high......good point Ian ill leave the bottom horizontal piece off and just leave the top one as it will be higher than the wall
