Morning all
This integrated shower outlet / bracket has quite a short 1/2" threaded connector on the rear. I'm connecting this to a 90 degree backplate elbow for support. But no matter how I connect to it, it seems I'm going to have to cut out some of the aqua panel.
I've looked for a backplate elbow with extended threaded section without luck.
Is there such a thing as a 1/2" male to female connector?
Or some other way I could tackle this?
I think I could come up with a solution without using the backplate elbow but then it would only be supported on pipe clips which I dont think would give enough support.
Found this in my plumbing box. I've no idea what its called!!
Cheers
Cheers
