The background is I put in a new basin in the ensuite over the weekend. There were no isolation valves on the pipework to make the job easier so the first thing was to put on a couple of those so the rest of the house could enjoy water whilst I worked away. The top part of the connector already had the bit of copper attached along with a compression fitting to enable the flexible hoses to connect in.
Now that I have added on the isolation valves and the new basin is much lower the plastic pipework needs to be shortened quite a bit.
As I don't have any experience of plastic pipework I don't want to start unscrewing the coupling and end up in a world of pain as I don't have any spares lying around the house for this sort of thing.
So if someone could give me a heads up on what type of connector this is and how to go about taking off a few inches off the length it would be great.
Also would I be right in thinking there are probably inserts inside the plastic pipe that I will need to remove and reuse before I start cutting through?
Thanks in advance.
Thanks in advance.
