Shortest length of floorboard that's safe
31 Mar 2010
Bradford
I'm guessing that having longer floorboards increases their strength. I'm not a carpenter it's just a guess. There is a very short section of floorboard between two floor joists and I wondered if it was safe.
What is the shortest length of floorboard between floor joists that's safe before it becomes better to remove more old floorboard so you have two longer ones?
These things are what being a carpenter is about imho, any idiot like me can lift cut and fit a few boards but we don't have the wisdom of the chippie to make the right choices
Thank's for sharing yours!
as long as the board has adequate support on both ends then its the span of 2 joist centers.
Mr gregers is spot on there. Unless the board is BETWEEN the joists as you said in which case it's not supported by the joists but by something nailed on the side of the joist then a span of two is good, after all the boards only have to support that distance, the joists do all the real supporting work and the boards stop you falling through the gaps.
idealy the weight is distributed over the whole floor for maximum stability and rigidity
if lots off short boards are used the floor will be bouncier than if you use longer boards
providing the majority off boards each side off the short boards cover several joists a few short boards here and there are fully acceptable and will not make the floor any bouncier
