Should Part P get scrapped?
How about a survey for the electricians here? If, say, you extended an existing socket or lighting circuit (not in special location etc.), would you feel that in order to comply with Part P's requirement for "reasonable provisions to be made ... to avoid fire or injury", that you had to undertake any testing - and, if so, what? - and, hence, whether you feel that a 'standard DIYer' (without any appreciable testing knowledge/facilities) undertaking the same work (without any specialised testing) would be compliant with the requirements of Part P.
Don't forget (did you know?) that when it first appeared, P1 said (with my emphasis)
Reasonable provision shall be made in the
design, installation, inspection and testing of
electrical installations in order to protect
persons from fire or injury.
I&T was removed in The Building and Approved Inspectors (Amendment) Regulations 2006
I am not saying there are no black sheep, but your suggestion is ridiculous.
I know it's ridiculous, and is not going to happen - on the contrary, the whole of the Building Regs system is moving over to Competent Person Schemes. However, that does not mean that they have yet ensured that all scheme members really are competent.
Given you don't work with electricians, why do you think that so many of us are sub-standard?
Firstly, what on earth makes you say that I don't work with electricians? - all I've said is that I am not an electrician. Secondly, what makes you believe that I think that a lot of electricians are sub-standard? (I don't - although I have come across a few whose understanding of basic electrical principles is frighteningly inadequate or flawed, even if they can recite 'the regs' to me backwards). It only takes a handful - since, unless they walk about with a label on their back saying 'Sub-standard Electrician', the general public will not be able to distingusih them from the great majority of perfectly competent ones.
Kind Regards, John.
Interesting. No, I didn't know that - and, particularly in relation to the discussion here, one has to wonder why they, presumably deliberately, removed it.
Kind Regards, John.
Maybe they felt it would have an undesired chilling effect on the ability of people to DIY?
Anyway - I'm going to select a few observations people have made above:
Look,
there does not seem to be all this **** kicked up about gas.
you gotta be registered to do it or else.
everyone seems to accept that and the registered bods charge for it.
In terms of risk, gas in most homes consists of a single appliance - the central heating boiler. Sometimes there will be a gas hob and maybe a gas fire. In any event, a very small number of items, and very little to go wrong or be tampered with.
If you feel that any reduction of 'avoidable' deaths is worthwhile, regardless of the 'costs' (in the broadest sense), then there is an almost endless list of things you should start campaigning for ... probably starting with dramatic reductions of (strictly policed/enforced) speed limits on all roads.
even prior to Part P the number of deaths due to dodgy electrical installations was, in cold impassionate terms, pretty insignificant - e.g. less than the number of deaths due to say, falls from ladders
Why?
There are a couple of sub-topics here, so without specifically quoting anybody...
Q)Why have a DIY Electrical Forum if all you're going to do is say "get an electrician"?
A) Some electrical work is too complicated, or requires too much knowledge, to be safely done by the unskilled and inexperienced, and after a while you develop almost a "6th sense" that tells you if the particular questioner is up to scratch. It's far from perfect, but I'd rather err on the side of caution than gung-ho. A real problem is that there are some tasks, e.g. CU replacement, rewire, sub-main to outbuildings, where there will often be holes in the person's knowledge of which he is completely unaware. In other words he doesn't know that there are some things he doesn't know, and asking questions about areas where he realises he needs to know more will not fill in the holes he cannot even see.
On a personal level, I believe passionately that nobody should ever do any electrical work, not even change a plug, without understanding the "why" of what they are doing. So whilst it would be possible for someone to add a 2-way switch on the basis of "insert the brown wire into L1" etc step-by-step instructions (what I've termed "electrics-by-numbers"), I'd rather they went and looked at drawings and gained an understanding of how it works. This is why I'll often say "see the For Reference topic"; it's not because I'm being dismissive, it's because I want them to learn what to do, not be told what to do, if that makes sense.
Q)Why so many references to Part P?
A) The fact is, that like it or not, Part P exists, and it is the law of the land. I think it is reasonable for people giving advice on building matters, e.g. drains, structures etc, to assume that everyone knows that the Building Regulations exist. But although discussing Part P has probably consumed more man hours than the hunt for free p*rn, it is still less than a year old, and there are still people turning up who don't know of it. There will come a time when we can stop mentioning it, but I don't think we are there yet.
My position is that I don't care if people (as private individuals, not professional electricians) obey the law when it comes to notification, but I believe that any decision to break the law should be theirs, and that it should be an informed decision. They should not be allowed to blunder into a position of having broken the law through ignorance.
Q) Should DIY electrical work be banned or seriously restricted?
I do all sorts of DIY, with varying degrees of competence, and for that which I can’t, or don’t want to do, I will use a professional. I’m a good painter and decorator, reasonable-ish carpenter as long as I know my limits, a crap gardener (mostly because of lack of interest), not much of a plumber (mostly because of lack of need to ever develop those skills), I’m a fabulous cook, I don’t do building/plastering/tiling, and, I genuinely believe, I am a perfectly competent electrician.
So yes, there is a great deal of self-interest in my position, but I make no apologies for that because my self-interest is the same as that of millions of other people.
I’m going to start building my case by looking at why people do DIY. As I see it there are 4 main reasons.
1) For enjoyment. Man is a tool-using animal, and there is a great deal of satisfaction to be gained from working with one’s hands to create something, and being able to stand back and say "I did that", particularly for people whose job isn’t like that. Gardening is the classic example of this - it would be a bit odd for someone to make continually rewiring their house or changing the wallpaper a hobby, but gardening is something that millions of people do for pleasure, and spend a lot of time doing it. But it is a form of DIY - they could always get a gardener to do it for them, and have the same end result to admire, but they choose to DIY because they enjoy it.
2) To save money. Pretty self evident.
3) To get a better job done. I’m not claiming that all DIYers will always do a better job than any professional, that would be ludicrous, as anybody who’d ever seen my bricklaying would be quick to point out. But there are times when a DIYer will achieve better results because of the amount of time they can lavish on a job. It’s often related to #2 - time is money, and there will be instances where someone for whom that is not true can do a better job than someone for whom it is. Take painting for example. The amount of work involved in, say, preparing a wooden window for repainting, particularly if it’s got lots of small panes, and decorative mouldings is huge. Nobody could make an economic proposition based around charging for doing it if they were truly going to do it as thoroughly as possible.
4) Convenience. There are times when the best way to get a job done is the 8AM start, bish-bosh all day long approach of the pro, and there are times when that level of disruption is unwelcome. Decorating is one example – DIYing at evenings and weekends will for sure take longer, but it will also be a lot less intrusive and disruptive to daily routine.
However, we do, of course, have to moderate the above for safety and community interest reasons. You can’t let anybody who knows how to mix mortar throw up whatever construction they want – you have to ensure that it is structurally sound, that it fits into planning rules etc etc. Even with gardening we’ve seen how regulation is needed to deal with the menace of Leylandii, and how H&S concerns have justifiable restrictions on what chemicals can be used and so on.
But in all instances it is the responsibility of Government to impose as light a touch as possible, and to only intervene when there is a compelling reason to do so.
CORGI regulations are often used as a parallel when arguing about Part P, but ironically the Gas Regs don’t prohibit DIY gas work, as long as it is “competently” done. I’ve never done anything with gas appliances apart from plugging a cooker into a bayonet fitting, so I don’t know how reasonable it is for a DIYer to acquire the necessary knowledge and skills, but I do know the following:
1) The potential for a catastrophic disaster with gas is much higher. Faulty electrical work might result in someone getting a shock, faulty gas work might result in a whole household dying in their sleep. A dodgy electrical connection might result in a small fire, and yes, I do realise that small fires can become large ones. A dodgy gas connection might result in an explosion, and there is no such thing as a small gas explosion.
I don’t know how many problems arise from non-CORGI gas work, nor what percentage of them are due to work that should have been done by a registered person as opposed to genuine DIY work that went wrong, but unless it can be shown that DIY work is a major problem I’d say that the rules were about right.
2) Gas is much less pervasive and much more static in people’s homes than electricity. By that I mean that there are millions of houses where there are but one or two gas appliances (boiler & cooker), once installed they remain there for several years – longer, one hopes, if they’re well made. They don’t get moved about, or frequently replaced as part of a makeover. Gas pipes do not run throughout the house, and they don’t very often need rerouting. People don’t want to add the ability to control their gas cooker from two places. They don’t have gas lights that they’d like to replace with some stainless steel ones they bought in B&Q. They don’t want to run gas out to the garden and the shed to power lights, fountains and tools.
In short, there is nothing like the same need for people to make changes to their gas installation as there is with their electrical one. Restricting DIY electrical work is hugely more invasive than restricting DIY gas work.
3) Gas appliances are expensive, and in proportion to the cost of the item, the cost of paying a CORGI registered person to install a condensing boiler is a great deal less, and therefore a great deal more reasonable to impose, than the comparative situation of having to pay a professional electrician to install a socket costing a couple of pounds. In the first case the labour costs are less than the cost of the item, in the second they are 10 or 20 times more.
Given that the impact of restrictions on DIY electrical work will therefore be felt by a very large number of people, and will have significant financial impact on a very large number of people, it is vital that there should be a compelling reason to implement restrictions.
In all activities that we fallible people undertake, there are risks, and the rules to moderate these activities in order to reduce the risks must be balanced against the costs, both financial and in terms of individual liberty. For example, on average around 10 people a day are killed on the roads in this country. The government rightly seeks to minimise road casualties by making drivers pass a test, imposing limits on how fast people are allowed to drive, how much alcohol they can drink, where they can drive, where they can park, how safe a condition their vehicle must be in and so on. They also encourage and force car manufacturers to make their products safer. They spend millions on public awareness campaigns.
But could anyone argue that they could not achieve a dramatic reduction in casualties by imposing a blanket 20mph speed limit? By an outright ban on driving cars when there is fog, or ice and snow? By raising the minimum driving age to 30? By banning the sale and use of motorcycles? All of these measures would undoubtedly save lives, but none of them would be introduced.
Why? Because their impact would be too severe. However rational a case you can make for banning motorcycles, ultimately you can’t deny people that choice. The limits on personal mobility, choice of lifestyle, choice of job – all items of fundamental importance to individual liberty would be immense if you restricted people to travelling at 20mph, or staying at home for days or weeks at a time in winter. The impact on the economy would be catastrophic.
Ladders. In 1999, about 28,000 people were killed or injured falling from ladders and steps in the home. We could probably save quite a few lives, and a lot of economic costs, if we banned the use of ladders & steps. Would anybody be up for that? Would preventing people from changing their own lamps, painting their own houses, using their lofts etc be a price worth paying in order to save lives, or would it be an unwarranted intrusion?
It is often claimed that people are at risk from poor workmanship, but when asked to show produce evidence of that a typical reply is:
“Why should we need to? It’s pretty obvious that electrically unskilled persons work can put people in danger.”
Can yes, but do? I’m afraid the evidence does have to be produced, for in a free society restrictions on people’s freedoms cannot be imposed on the basis of “It’s pretty obvious” – you must be able to show that there is a severe problem.
I don’t want to be stopped from doing something that I find satisfying, I don’t want to have to pay 10-20x the cost of materials for someone to fit them, I don’t want to have to organise my domestic schedule around the efficiency needs of a tradesman when I need something done. And I suspect that neither do millions of others.
I’m not saying that no dangerous work is done – I’m saying that before you reduce my quality of life, and forcibly increase my financial outlay, and damage the business of companies that sell electrical products, you must, absolutely must, show that the amount of dangerous work is so great that it cannot be tolerated, and just like I’m not free to drive while I’m p****d, or at 100mph down the High Street, I can’t be free to do my own wiring.
Anyway - I'm going to select a few observations people have made above: .... Why? ... Well, 6 years ago (with added highlighting in this quote) I wrote .........
It presumably will come as no surprise to you that, 6 years down the road, I more-or-less totally agree with all of what you wrote back then (and, indeed, having been writing some of those same things in the last couple of days in this thread).
Kind Regards, John.
Kind Regards, John.
Okay then, what do you do for a living? A while back you asked which of us were professional and which were diyers? What do you do, which brings you into conatct with so many electricians that you can derive that enough are not competent to sign off their own work?
I don't get your logic here. You seem to believe that the only way to be sure that a domestic install is safe is to have an LABC inspection. Given that as an electrician, the certificate is the proof that it is safe and the LABC bit is basically a rubber stamp to this, I don't see why you are so against us self-certifying. Scrapping the self-cert scheme would cost a fortune and swamp every LABC. Given, even you admit most electricians are competent, this is a draconian suggestion.
Even though you've quoted what I said, you don't seem to have got my point. Why do you keep saying 'so many'? As I said (and you quoted) it only takes a handful of 'black sheep' to make it impossible for anyone to know whether or not any particular electrician is competent to self-certify.
Anyway, as others have said, third-party inspection/approval/certification of their work is something which many people happily accept if they work in safety-critical areas. How comfortable would you be to fly in an aircraft just after its engine had been worked on by a fitter who had 'self-certified' his/her work?
Any certification system which consists of merely rubber-stamping the electrician's (or DIYer's) assessment of their own work is obviously a joke which is not worth having. Returning to the aeronautical analogy, tragedies have occured when inspectors have merely 'rubber stamped' the work of fitters they believed to be competent. The other thing to remember is that even the highly competent are not immune from making mistakes - another reason for third party inspection/certification.
Kind Regards,
John
A somewhat different kettle of fish, I think, both in size and in risk.
These figures are from the proposals for Part P, and so are out of date, but I don't imagine they have changed significantly.
  • There are about 61,000 electrical contracting firms in England and Wales employing some 106,000 electricians.
  • Each year about 2.8 million wiring installations are formally undertaken by electrical contractors.
How many aircraft engine fitters are there?
How many aircraft engine maintenance activities take place?
How many people can be harmed, and to what degree of harm, by the failure of a single aircraft engine maintenance activity to be carried out properly?
How many people can be harmed, and to what degree of harm, by the failure of a single electrical installation activity to be carried out properly?
How does the average cost of an aircraft engine maintenance activity compare to the average cost of a domestic electrical job?
When you compare passenger miles per aircraft engine maintenance activity with number of residents per domestic electrical job which has the better capacity to absorb the cost of independent inspection?
No argument about that but, as I'm sure you understand, it's part of the spirit in which my comments have been made ... I think there is a tendency for some people to 'want it both ways' in relation to electrical work. On the one hand they want to present it as a highly safety-critical business, with the most extreme consequent suggestion being that all DIY electrical work should be outlawed - but, on the other hand, they are not happy to have the activities of 'professional' electricians dealt with in the manner one would expect in relation to safety-critical activities.
Kind Regards, John.
They don't want it both ways - they just want job protection/restrictive practices legislation.
There's no rationality in their position. Don't forget that earlier today we saw someone who works in a regulated field with mandatory qualifications and safety critical aspects get completely bent out of shape at the suggestion that other fields might require him to know something.
They don't want it both ways - they just want job protection/restrictive practices legislation. There's no rationality in their position.
I don't think we're really saying anything different. Wanting the job protection/restrictive practices legislation (and using the safety-critical nature of the work as a justification for it) but not wanting to submit to third-party inspection/assessment of their work strikes me as 'wanting it both ways'!
Kind Regards, John.
I see no real reason why folk can't self certify, but (there is always a but)
Licensed Aircraft Engineers are subject to audit, airline pilots have to attend simulator sessions every 6 months to keep their skills up to date, airline cabin crew (the safety bit is in the event of a crash they are the ones who will help get you out) every year, I am subject to annual audits and annual refresher sessions (as are all DNO authorised staff)
Are electricians subject to any of the above?
Probably fair to say that the vast majority comply with the requirements for standards and testing - but there are (just look at some of the horror stories on here) that do not, these are the ones that the industry needs to deal with
I see no real reason why folk can't self certify, but (there is always a but) .... Probably fair to say that the vast majority comply with the requirements for standards and testing - but there are (just look at some of the horror stories on here) that do not, these are the ones that the industry needs to deal with
Indeed - and, as you say, it is the industry's need to deal with that few that results in the 'but'.
Kind Regards, John.
And one way to deal with it could be zero tolerance.
First time you get caught not testing, or in any way falsifying an EIC etc, and your licence is revoked and you go back and do your training from scratch again - all the C&Gs, all the exams.
Second time you never work as an electrician again.
There is no 3rd prize.
And one way to deal with it could be zero tolerance. .... First time you get caught not testing, or in any way falsifying an EIC etc, and your licence is revoked and you go back and do your training from scratch again - all the C&Gs, all the exams. .... Second time you never work as an electrician again.
Well, never work as a self-certifying electrician again - unless you're suggesting than no-one other than 'licensed' electricians be allowed to undertake any electrical work.
I certainly think that (maybe they already do?) the scheme operators ought to conduct random 'spot checks' (hopefully 'when least expected':-)) - otherwise few rougue electricians would ever get 'caught', no matter what the penalties.
Kind Regards, John.
