A bit of electrical advice please...
Just in the process of replacing an old Watermill electric power shower with a Mira Vigour. Unfortunately, the cable (flex in fact) doesn't reach the terminals of the new shower. Some details about the set-up...
- the supply is via twin and earth flex buried behind the tiles (definitely no slack), running to a 3-pin plug socket in the neighbouring bedroom.
- There is an RCD on the consumer unit
- The Mira Vigour is rated at 150 Watts
Because the footprints of the old and new showers are different, which exposes the cable entry point, I intend to use a short length of surface trunking to route the flex into the new unit - this will also serve to hide the entry hole through the tiles (fortunately this is quite small and neat).
With this set-up, about an inch of flex would reach inside the shower via a top entry point, and once inside the unit it would run very close to the hot and cold supplies. So I would like to know what would be the accepted way of extending the supply by another 6 to 8 inches to reach the terminals, and whether the solution(s) is classified as notifiable work.
Thanks in advance
Matt
Thanks in advance
Matt
