Morning all!
I installed a pivot shower door from Wickes a few months ago and there's been a problem which is progressively getting worse.
When first fitted you had to push the door slightly closed, then open it a bit and then push it again to close it. I presumed this was to due to air being moved by the door.
However it has now got to the stage where the door will not gently close on its own (i.e. by the force of the magnetic strip), you have to really push it or pull from the inside.
The problem seems to be at the bottom of the door.
The vertical and horizontal planes the door is fixed to are plumb/level so it's either,
A) In need of adjustment
or
B) A sh!te door
As I'm currently at work I thought I'd post on here to see if anyone's had a similar problem and could offer a solution.
or
B) A sh!te door
