shower elbow outlet connector problem
7 Jan 2008
Newcastle upon Tyne
Hi all,
I'm in the process of reconfiguring my bathroom and I've hot a 'little' problem. I have a fixed mixer shower head with a secondary outlet for a handheld shower, which is connected via a flexi-hose to a 'designer' elbow.
After tiling it seems that the thread isn't quite long enough to reach the wall mounted female elbow connector concealed within the wall. I have a contingency plan, but wondered if there is a way of 'extending' the thread to reach?
The male connector has a hex key internal and can be removed from the 'designer' elbow, but the thread is a lot narrower after the rubber seal into the elbow than the regular tap type thread used for connecting to the elbow to the female wall mounted elbow situated in the wall behind the tiles, are any of the below options possible:
- extending regular tap male thread?
- a 1/2" male to 1/2" female coupler (I think these are the sizes??)
- a replacement and longer male 'tap' thread that will connect into the elbow with a narrower thread after a rubber washer
Any advice gratefully received.
Cheers guys.
