Hi all , got a catridge style CU with a single 45A 'powerbreaker' switch next to it that was once fed from the main CU. This 45 then went to the old stairlift in the house (overkill i know).
Anyway, we need to run a feed to the shower (10.5kw) . So, i know the CU is capable of supplying the 45A needed supply, but i'm unsure of the regulations.
Can we simply run a 10mm cable out of the catridge CU into a single 45A trip sitting next to it? then on to the shower? Or will we have to have something else done? Can i run the cable myself? or will an electrician have to do it?
Obviously i'm going to have it wired up properly by someone .. but i just wondered if we can get away with our current set up , and if so what work i can do myself beforehand.
ta..
ta..
