Shower head
7 Apr 2013
Herefordshire
Have a waterfall type shower where the decorative shower piece has dropped out. If I push it back on there is not enough grip to hold it tight to the main unit and water overflows around the edges. Is there a string waterproof adhesive I can use to hold it in place?
Sure, an epoxy adhesive such as araldite should work well here....the shower head needs to be completely dry though, and tape the offending item in place until the adhesive has cured.
This will be permanent, mind you!
John :)
